I have found all kinds of conversion instructions for everything else except this.
I know I can use Virtual Dub, But I was wondering what settings I would need. I have tried it once and got a file that was over 1G.
Any help would be wonderful. And this has already been posted somewhere I am sorry. I did do a search on the forum but could not find it.
Use Virtual Dub again. Before saving, select Video-->Compression. Select the MPEG-4 codecs to get good compression. This assumes you have the DivX codecs installed.
Hello. -
what is your mpg? mpeg1 or mpeg2?
you can do this if its mpeg2
http://www.vidomi.com/faq.php?myfaq=yes&id_cat=4&categories=Using%2BVidomi#10 -
I like to use Mpeg Mediator when i do dvd ripping and encoding, load your vob files into it, and only encode the video with Divx 5.0.x at 100% 1-pass quality with quater pixeling and bidirectional encoding on, do not compress audio or it will go out of sync, use PCM(uncompressed). you will get about 400MB/per 23 or 24 minutes, then use Virtual dub and decimate the video by 2, use the smoother filter at 100% with noise prefilter, Use Divx 3.11 Fast Motion at default settings, compress the audio with WMA V2 64kbps 44.1KHz for Audio/Video, and do a conversion to 44.1 with the high quality box checked. This should produce video at about 100MB per every 50-55 Minutes, at DVD Quality. (Important, do not run any other programs during any process involved with ripping or encoding, it can cause unexpected errors and larger file sizes.)
To burn or not to burn, that is the question.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
