I used DVDx to convert a DVD to a VCD...when I played it on my DVD player (Pioneer DV-C503), it came up in the top left corner of my screen (about 1/4 of the screen size). I then tried to use FlaskMPEG with bbmpeg to rip it and it came out full sized (but I wasn't able to forward/rewind without losing the audio). I really like DVDx because it's so simple, but can anyone help me fix this problem i'm having...Does it have anything to do with Nero 5.5.2.3? Thanks.....
I have the same ff/rw issue on my Panasonic DV30. I found that after ff/rw all I had to do was pause/still the picture then press play and the audio would be back. I'm also using DVDx (and DVDDecrypter/Smartripper) and the same version of Nero, but haven't seen the top left corner problem.
try using easy cd creator, i used that and it worked like a charm,
Dhruv -
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
size problem with brrip
By krtsa91 in forum Blu-ray RippingReplies: 3Last Post: 21st Feb 2011, 00:21 -
Problem with DVD output size
By senecalax25 in forum Authoring (DVD)Replies: 2Last Post: 21st Sep 2008, 03:08 -
video size problem
By tomchook in forum Video ConversionReplies: 3Last Post: 29th Aug 2008, 22:12 -
DVD size problem
By ranchhand in forum Video ConversionReplies: 10Last Post: 10th Sep 2007, 15:42 -
Estimated Size Problem
By NHLroyrocks in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2007, 01:17
