i am using dvdx 2.0 to encode a dvd movie that i ripped using smart ripper.
on the output settings, i chose to encode for vcd mpeg and the following settings are required:
video bit rate
audio bit rate
max frame
i also choose custom chapters and it requires to a bitrate.
so my questions, how do i determine the value for these settings?
video bit rate, audio bit rate, max frame, bitrate.
tvandang
tvandang
Just select VCD (mpeg 1) and don't change anything concerning bitrate. It will create compliant VCD. If i'm not mistaken, VCD bitrate is 1150kbps and audio has to be stereo, 224kbps.
Frame rate should be 24 i believe (for PAL).
D.
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35 -
MP4 video playing at a faster rate than audio
By Teroxgt in forum Software PlayingReplies: 0Last Post: 21st Jul 2011, 02:15 -
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 15:55 -
audio bit rate showing in video
By soulman1015 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 11:44 -
DVDx dropping audio at end of vob
By shira in forum DVD RippingReplies: 0Last Post: 21st Jan 2008, 23:42
