  1. I'm sorry. But my computer is a 350 MHz P2 and is still doing well. Of course no video stuff. However I need a new soundcard and was thinking about a card including a FireWire port. Will a 350MHz P2 have enough performance to capture DV video via this FireWire port?
    Thanx for your help.
    Mr. Pickert
  2. Please. A simple YES (or NO) would be enough.
    Thanks.
    Mr. Pickert
    Nov 2000
    GLoucester
    Yes.
    The link provided is for the Soundblaster Audigy. This has built in firewire. It also gives the specification of the the systems it can be installed in.
    http://www.soundblaster.com/products/audigy/system.asp
    Most capture problems, dropping frames etc can be overcome by fitting a second dedicated hard disk for capturing to.
    Hope this helps
    TOMMO
  4. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Yes, your machine is fast enough to capture DV
    http://www.vcdhelp.com/forum/viewtopic.php?t=111740&highlight=firewire
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
