I have been trying to install this product and have been unsuccessful. I put the hardware in, and start Windows XP. Window XP sees the new hardware, and prompts for the installation CD. The files are copied, but Windows display a message "Can't start Hardware - Code 10". Has anyone had a similar problem?
Results 1 to 10 of 10
Do you have a live video source connected? I don't think the setup works properly unless you do.
Yes!! I'm having the same problem with Windows 98, only it says "failed to create TV window" when I launch WinTV 2000. Can anyone help? I just dropped $150 on this piece and I really, REALLY don't want to have to return it. Anyone? Thanks much. -JM
EDIT: It makes no difference if the source is hooked up during setup. -
Latest drivers downloaded, and have you visited the web site?
Hello. -
PVR 250 help: www.shspvr.com (look under news for latest drivers)
Panasonic DMR-ES45VS, keep those discs a burnin' -
JMTapes if newer drivers and apps don't work try change overlay mode by going to Start | Programs | Hauppauge WinTV click on Primary icon.
never mind I see it French saying "Thank you very much" you welcome
I would like to thank everyone that helped with my problem using Hauppauge. I never got the software to work so I took it back to the store. I bought a PVR/Video software by a company called Aver. The software installed without any problems. I hooked my cable up to the card, pressed scan stations and it worked! I also recorded a show in mpeg-2 and it worked! I loaded it into Ulead DVD and created a dvd image. The quality was not bad. I guess I have nothing to compare it to since I never got ATI or Hauppauge to work. I am still testing the software for bugs. But right now it is working fine. And the best thing about this package was that it only cost me $49.95! This company has a website (aver.com)
Happauage WinTv PVR 250, software concerns and advice.
By MidnightMike in forum Capturing and VCRReplies: 6Last Post: 25th Aug 2011, 11:37 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00
