am trying to create a wav file from a high quality avi file. However when i open the avi file in virtualdub I get the following error message
Virtual Dub has detected an improper VBR audio encoding in the source file and will rewrite the header with standard CBR values. This may introduce up to 11350 ms of skew from the video stream. If this is unacceptable (which it is) decompress the entire audio stream to an uncompressed WAV file and recompress with a constant bit rate encoder. Bitrate : 190.4 =/- 22.3kbps.
erm ... what does this mean and what do I do now ??
Closed Thread
Click on audio and select full processing mode, also select convert to 44.1khz (if creating (S)VCD), click on compression and make sure no compression pcm is selected. Then click on file, save wav as, and save the wav file. The file will be large, about 10mb/min. If you wanted to create an mpeg for vcd or svcd, this is also the method you would need to use to make sure the audio stayed in sync. You would use this wav file as the audio source when encoding.
Craig
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 09:56 -
I want to dub both audio files to the same movie but sync problem
By amdsamurai in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2011, 08:03 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 19:45 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 13:35
