Can anybody tell me is there any difference in hearing between MPEG-2 48000 Hz 256 kbit/s and 384 kbit/s coding?
Thanks...
Beauty is in the ear of the beholder. The only way you will know for sure is to try for yourself. Just encode a small clip with each and see if you find it acceptable.
In my own opinion, I think 224 sounds find for any 2 channel sound configuration (stereo, joint, dual), but for 4 or more channels, I think a minimum of 384 would be a necessity.Impossible to see the future is. The Dark Side clouds everything...
DVD coding
By Ciz41 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Dec 2010, 04:02 -
{/a6} coding in ffmpeg?
By misook in forum MacReplies: 0Last Post: 14th Nov 2009, 14:57 -
Coding in GK
By eliqush in forum EditingReplies: 16Last Post: 12th Oct 2009, 22:17 -
Audio sync problems when re-coding captured video. Any Solutions?
By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 18:34 -
DVD Region Coding
By jasej in forum Authoring (DVD)Replies: 5Last Post: 27th Jul 2007, 08:59
