I use virtualdub to put subtitles and to do a frame server and then i encoded to mpg2 whith TMPGEnc Plus but now the movie stay whith purple shadows and i dont now why.
I use the nimopack and it appends whith the last to movies that i try to encode to mpg2(The sum of all fears[Xvid] and Windtalkers[Divx]).
Does anyone can help me?
Thanks in advance
If you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello.
Problem with Virtualdub
By pranjev in forum Newbie / General discussionsReplies: 25Last Post: 30th Dec 2011, 13:16 -
VirtualDub Problem
By jarko in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 13:26 -
VirtualDub problem
By nic3 in forum Video ConversionReplies: 3Last Post: 1st Dec 2009, 14:29 -
problem w/virtualdub
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 8th Apr 2008, 00:09 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
