when i try to create a dvd image with ifo edit i get a img.dll message
i think this is to do with xp
however i got imgtools which i eventually got to work after similar errors
my problem is i got it to work by trial/error and guesswork as to which dir,file,folders to use now i cant figure out what way to do it again
i rip using dvddecryptor(file mode) and then put thru ifoedit
i then put in the path to the resultant video_ts folder
but get an error saying it cant find the said folder i make an "i"drive which has all the files of the dvd
i have tried this several times with different dvd all <4.3gb and work thru the file mode of power dvd
i know this is possibly a simple thing but i cant create a dvd image
the really frustrating thing is i have already burnt successfully a dvd5 and dvd9 movie and just cant figure what i am not doing this time
thanks in advance
cheers mick
I can't see your question - here in the US we use punctuation in our English and the "?" helps people pick out the questions so we can answer y'all
How can we help?Panasonic DMR-ES45VS, keep those discs a burnin' -
well spotted batman , sherlock holmes could have done with a cat to help him.
i actually did not ask a question i just stated what i can`t do, which is create a dvd image from my ripped dvds.
then again if i cannot punctuate properly maybe there is no hope.
so pleading ignorance , how do i create a dvd image ,after ripping a dvd ,using dvd decryptor in file mode ( dvd <4.3gb) ???
thanks again
mick
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
