when trying to encode using TMPGEnc (various versions) it crashes but never in same place of movie.have tried this 5 times and best yet is 1hr 10mins of 1hr 30 movie.read different guides and tried different settings-no joy HELP please
What are you encoding? and is this source error free?
/Mats -
i am trying to encode shallow hal which i ripped using smart ripper.
load up the wav file and d2v ,video starts working then just crashes the computer.
as for is the souce error free god know you lost me im new to this -
1) try to reboot the computer right before you're about the encode so you can clear up the memory
2) ctrl-alt-del and close any unecessary proggies (i think all the ones you really need is explorer and systray...not sure if others are needed) -
I was having the same problems with error messages. I read some articles here and started converting my audio files into WAV format. I haven't had a problem since.
First you need to download the Virtual Dub program. Once you've done that:
Open the AVI in Virtual Dub, go Audio->Full Processing Mode, then Audio->Compression->no compression(PCM), then Audio->Conversion->44100Hz->OK, then File->Save WAV and choose name for file and save it to whatever folder you will remember. This extracts the audio, now just load both files into TMPGEnc and encode as usual - should work just fine.
Run a search on this site to find the Virtual Dub download. On my 2000 Pentium it only takes about 45 seconds to save the audio to WAV so it really isn't any problem or hassle at all. -
Oops, sorry!
I use the Virtual Dub program to convert the audio on AVI files. I don't know if it would work with a DVD rip
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
