Hi,
Sorry for the newbie question, but I'm stuck!!
Followed the rules for avi to vcd:-
virtual dub for bad frames check, then save wav
tmpgenc for making mpeg (pal)
nero for making vcd
checked vcd contents and all is should be, as far as I can tell!!
put in dvd player (video cd) no disc
any ideas, help.
Not sure if I'm getting the whole ntsc/pal thing, do you have to keep the same format when making an mpeg?
cheers
Gary
Is your DVD player compatible with VCD and CDR, not all are. Check the DVD compatability list
Craig -
Try VCDEasy for authoring your VCD. Like you, I never succeded in making a VCD my standalone DVD would accept. VCDEasy works each and every time.
/Mats -
cheers guys,
checked the player compatible list and it looks like it my sony doesn't like cd-r's. videocd no problem!!
will try cd-rw's
cheers
Gary
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 19:52 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12 -
DVD-R burned using a DVD Recorder wont play on any other player
By weaseal4 in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 12:37 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
