  1. I'm trying to frameserve with virtualdub to tmpgenc,cause i want to get permanent subs in Blade2, everything looks good until i get to the part "source range",where i should cut it. TMPGEnc says "Reading error" ?? It must be the audio in Blade (which bytheway i must use nimo codecs to play).For when i frameserved with "no audio" it went well. I also tried to get a wave file and convert it in TMPGEnc with the avi...but no...still a reading error...?
  2. Just ignore the error and go ahead with the cut. I often get this error but it does not seem to effect the cutting process.
    Craig
