I saw a guide using FitCD to make a 1CD mpeg for a DIVX that i downloaded. Using the exact same bitrate Fit CD gave me, in TMPGenc via CBR, the file size still blew out to over 900MB when i entered 1 80 min CD in fit cd.
why?
FitCD also gives you a bitrate for audio,did you use the audio bitrate FitCD gave you? I have found FitCD to be very accurate.
This is just a suggestion, but I read somewhere recently that using versions 4 & 5 of divx makes it difficult if not impossible to calculate file sizes because of the way it encodes.
I have found that fitCD incorrectly detects the length of the source movie - by like 20 minutes - at least dv2 files.
Just make sure you input the proper length in the upper left hand corner of the program. Once you do that it's dead on accurate.
-d
Fit to disk in AVStoDVD?
By Des in forum Video ConversionReplies: 7Last Post: 3rd May 2010, 23:36 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 06:23 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 22:49 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 12:46 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 23:57
