First let me say that I appreciate all the help i've had so far here. Many are very knowledgeable.
My only problem is now, I am coverting from avi to mpg (to make an svcd). After the encode, the quality is seriously degraded. What tweaks can I use? I tried noise reduction, ghosting, and sharpness, but in the black areas of movies, it was way too saturated and you can see blocks, whereas in the original, it is a perfect black background. When I click on custom color, under the advanced tab, nothing happens. How do you set up custom colors or how do I make these adjustments?
Thanks again.
i have the same problem. i know how u feel. i haven't found a way to fix this yet, but i am still learning. i went ahead and just d/l'ed the mpeg files ready for vcd as a ways of going around it. does nobody know what this problem is?
I figured it out. You have to *double-click* custom color correction. Then a box will pop up. I then set the RGB for each color down -30. This fixed the problem!
Thanks! -
so it's not so pixelated in the dark areas now? i'm gonna have to try that. thanks for the post.
Re-Encode with Minimal Quality Loss
By Bruno AUgusto in forum Video ConversionReplies: 2Last Post: 18th Mar 2012, 17:26 -
Can't get good quality x264 encode
By silverwolf0 in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2011, 21:45 -
Does a middle encode harm the quality of the end result?
By PuzZLeR in forum Newbie / General discussionsReplies: 8Last Post: 21st Jul 2009, 19:26 -
How to encode High Quality MKV to (SD) AVI?
By whatever911 in forum Video ConversionReplies: 13Last Post: 4th Dec 2008, 22:46 -
How do I encode VBR to CBR without losing quality?
By rocky12 in forum AudioReplies: 7Last Post: 1st Oct 2008, 11:59
