im using TPMGEnc and burning with Nero 5.5, and when my dvd player plays the VCD, it takes a good 5-10second pause while continuing to the next track. is that normal? because if i were to make a movie with chapters, the pause would be extremely annoying.
Results 1 to 10 of 10
Yes thats normal. There will almost always be at least a slight pause. You can minimize the pause by burning in dao and by setting the pause time to 0 in nero, but whether you can get totally seamless transistion depends on your dvd player. If your dvd player still causes a pause then you should just settle with the chapters that are supported by the vcd standards. Use video pack 4.0, I-Author, or vcdimager to make true vcd chapters. They don't function exactly like dvd chapters but they will play seamlessly on all dvd players and still allow you to navigate through your movie.
is this all one movie?? if so, why dont you join the mpgs together as one file before burning..thus elimanating the multiple tracks??...you then won't have to worry about the pause
What I'm making is an mpeg concert on VCD. I want to be able to skip to any song but I also want to be able to watch it seamlessly. Any ideas?
The problem is in Nero it defaults with a 5 second pause between tracks. Layout all your tracks in the layout, right click the track, go to properties. Change the pause from 5 seconds to 0 seconds. Done Deal.
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
You should make all your clips on long/big MPEG then use VCDImager to add tracks to the I-frames. This will get rig of the pauses but still allow you to hit next/skip to go to a new section of the x(S)VCD.
multiAVCHD prevent pause between tracks
By yoboha in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Sep 2010, 08:17 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
dvdplayer on pause
By steplock in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Jun 2009, 15:05 -
Pause video using Avisynth
By roglopes in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2009, 14:41 -
Can you pause in MKVEtract?
By Maikeru-sama in forum Video ConversionReplies: 0Last Post: 30th Jun 2008, 08:55
