I have a VHS Source tape that has Good Video but the Audio is Jittery (like talking on a bumpy road). If I extract a wav file from my capture, is there a way to smooth it out using an outside editor like Sound forge or something? and if so will I have a problem placing the "corrected" audio back into the video file?
Thx
Demultiplex the audio and then you can use any filters in sound forge, cool edit or any program but be sure to not edit the length of the audio.
Multiplex back the audio and it should be in sync.
www.vcdhelp.com/faq#demultiplex
www.vcdhelp.com/faq#multiplex
Jittery Flickering!
By Soixante in forum ComputerReplies: 4Last Post: 27th Sep 2010, 07:11 -
DVD To Xvid - jittery, please help?
By kpoman in forum Video ConversionReplies: 5Last Post: 25th May 2010, 18:59 -
jittery slow motion scenes
By Dr_Layne in forum Capturing and VCRReplies: 1Last Post: 25th Aug 2007, 20:36 -
burning avi file is jittery
By fredted40x in forum Video ConversionReplies: 1Last Post: 4th Jul 2007, 12:48 -
Jerky, Jittery DVD
By leng in forum Newbie / General discussionsReplies: 18Last Post: 24th Jun 2007, 11:15
