I have become interested in video editing (mostly short video clips) on the computer. At this time, I do not want to buy a DVD burner untill they are more affordable and also they standardize format. (DVD-RW ,DVD+RW, DVD RAM who wins out?) I have been using a Sony Digital 8 Cam Corder, a firewire and ULead Studio 5 Templates (Highest quality Mpeg2 setting -Resolution NSTC 720 x 480 ) for compression. I then burn the compressed Mpeg2 files as a data cd. I know this is really not a format. (maybe similar to a miniDVD or a cDVD I guess.) However I get excellent quality, and believe it or not the cdr's do play in my standalone DVD player. ( Magnavox MDV450SL) Cdr discs are inexpensive and I'll sacrifice time on the cd (I only get about 20 min.) for quality. I want to go DVD in the future and the editing is alreay done on these data cd's to save time. Does anyone know if it will be easy to compile these compressed Mpeg2 data discs to DVD or should I go in a different direction?
This is a great website for information....Iam enjoying it very much....Thanks for reading and I would greatly welcome input or suggestions. Huskerboy5
Video killed the radio star.........
what you are doing is the way to go and you should have no trouble with the MPEG2 files going to dvd at a later date.
Thanks for the help.........Huskerboy5
Video killed the radio star......... -
You do need encode the audio at a 48000 sampling rate to be DVD compliant. 720x480 is the best resolution to use but you'll need to reencode the audio if you don't use 48000 audio sampling rate.
Thankyou...... I had not thought of the audio specifications of DVD.
BD backup file storage: which format? H.264, .mkv, .m2ts,
By jlm86 in forum Blu-ray RippingReplies: 6Last Post: 21st Feb 2011, 15:27 -
Best video format for long term storage of home movies
By Airjrdn in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2011, 17:14 -
Long term storage format.
By DaveQB in forum RestorationReplies: 1Last Post: 23rd Oct 2009, 07:37 -
Best lossless format for storage/future editing for Hi8
By jkryan in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2009, 23:33 -
Best format for storage
By trikcard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Apr 2008, 10:18
