I recently converted a movie which had an AC3 audio into one using uncompressed wav. The resulting file plays OK with VirtualDub but when I use Windows Media Player, there is a certain periodic static in the audio. I have all the divx codecs plus the NiMo codecs installed. What compression should I use on the audio such that I can remove the static when playing with Windows Media Player? BTW: The original movie file (which used AC3 audio) had a sampling rate of 48000 Hz and had channels on stereo. Thanks.
Results 1 to 1 of 1
Phillips DVDR600VR: periodic dropout
By Super Leviathan in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Jun 2010, 19:32 -
removing one audio track from an avi movie file
By srckaimal in forum AudioReplies: 1Last Post: 4th Nov 2009, 20:28 -
Periodic static band in old VHS
By lighthearted in forum RestorationReplies: 8Last Post: 29th Jun 2009, 05:28 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 15:33 -
Editting (removing) Audio from Movie DVD
By CaLiFol2niCaTioN in forum AudioReplies: 3Last Post: 8th Dec 2007, 16:47
