First let me say that I didn't really read this entire post but, I would suggest some sort of DV route.
Also if you are really concerned about the condition of the tapes. You might want to consider having them done by a "professional" place like Industrial Color Labs or similar (note the quotes on professional). The real professional tape dubbing, restoration places are a little expensive but, there are a lot of things that can improve old tape. Like running them through a cleaner first, etc. Yes I've had to do it with old tape. Not VHS but old 3/4 inch Umatic stuff. Sometimes you just have to send them away. if the tapes are still in good shape, then by all means cap. the suckers. But if you are getting excessive drop outs, you might think about having them done.
Results 31 to 32 of 32
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
You are being given good advice. None are wrong. However, there are certain advantages to buying a PC first.
If you do, it needs plenty of RAM at least 512MB. A second dedicated hard drive for capturing video onto. Much better results that way. And obviously a good processor speed for encoding. If buying a capture card to capture your existing footage, try to get one that capture both analogue and DV, don't pay over the odds for one, a firewire card is an inexpensive addon later.
What would you have more fun with, a new computer (probably) or a new dv camcorder. When you have answered that question for yourself you have your decision.TOMMO
Is there a 3CCD Digital 8 camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 21st Dec 2023, 22:32 -
looking for digital camcorder software
By TracyH in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Aug 2011, 23:10 -
digital 8 camcorder purchase
By Surfmaster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd May 2009, 20:57 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47 -
Digital 8/Hi8 Camcorder
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 28th Oct 2007, 13:40
