  1. I have backed up numerous dvd without any problems. I am having a problem with Insomnia staying in sync after authoring. It seems the audio gets out of sync during the 6 second rating view . I am ripping the entire dvd to hd , then using dvd2avi to create audio and d2v file. Then using cce to shrink the file to fit onto 1 cd (movie only). I have even tried using ifoedit to strip out that VOBid for the ratings but the sync still is off after remuxing and authoring..
    thanx so much if anyone can help
  2. Nevermind , multiple pgc movie
