Hi,
I have a separate DivX 5 .avi file and a separate .mp3 file. I'm wondering which program/s are available which will multiplex the two files.
I started off with a captured VCD file of a tv prog, but virtualdub wouldn't allow me to automatically convert the VCD to the desired .mp3 quality, so I converted the vid without sound, then made a .wav and converted that to .mp3. Thus, I'm wanting to join the .avi and .mp3.
Any help would be great. Cheers.
Shaggy
euhm... well, does it HAVE to be an avi?
Otherwise i'd suggest you do convert it to mpeg and form there you multiplex in tmpgenc.
i'll think about it.. but i think i don't have an answer for you...
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:26 -
Converting AVI file with separate subtitle track
By dgarmaise in forum ffmpegX general discussionReplies: 2Last Post: 7th Jun 2008, 08:08 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Playing an avi with a separate sub file in MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 31st Dec 2007, 11:05 -
AVC FILE to AVI/MP3 File: How to Convert?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 25th Jul 2007, 21:49
