  1. Hi, can anyone tell me how to convert .vcr to .avi or .mpg? Im using an ATI All-In-Wonder 128 Pro. I have MMC 7.7.
  2. actually, i think you can just rename it .mpg. i think they just add extra meta tags and header info. you may want to remux in TMPG too. but i'm pretty sure it's just an MPEG with a different name.
    Jul 2002
    Erie, PA United States
    AzNDrAg0nBoi12,
    Actually the easiest way to convert that file is to open it in the media center, right click on it, and select export to mpeg-2.
    Warning! I'm baaaaaaaaack
  4. which program from the media center do i use kayfam?
    patrickm, i tried renaming it to an .mpg and a .mpeg it didnt work. I also tried to use the Library and export it as an .mp2 and then renamed it to an .mpg and .mpeg, both didnt work
    Jul 2002
    AzNDrAg0nBoi12,
    Open up the library, select the file, right click and export to MPEG-2. Sorry I should have made myself clearer.
  6. there is no option to do that. it says to Export to .mp2 but not Export to MPEG-2. I tried renaming the .mp2 file to .mpeg and .mpg but it didnt work
  7. i use ati-all-in-one wonder but i don't use it to convert it to vcr. may i ask why you are using vcr format?
    are you trying to record a tv clip or vcr clip?
    i have tried to record a tv clip and a vcr clip and played with different format mpeg-1, mpeg-2, divx5.0, wmv and found out that the best quality of clip was wmv(windows media). the others, you noticed the quality was bad but wmv format, the clip was excellent.
    for windows format, for a 700 mb, you can record up to 1 hour of clip with
    resolution 640x480. this is what you can do if you try to fit these clips on a 700 mb cd.
    you can either (1)record for one hour and then stop the recording and the vcr or (2)if you know how long the vcr tape is, then set the record setting for 2 hours if the vcr tape is less than 2 hours.
    1. rewind the vcr to the point when you stopped record and continue to record it again for the rest of the vcr clip.
    2. after 2 hours of recording, your file would probably be around 1.4 gb and therefore too big for one 700 mb cd. you cannot use virtual dub to split this file into 2 so that each can fit on a cd.
    so use TMPGEnc to split it.
    let me know how things work out for you.
    tvandang
  8. Originally Posted by AzNDrAg0nBoi12
    ati calls their mpeg-2 files .mp2. export to that.
