Well, I am out of ideas. Using VCDEasy for creating chapters, I get "CDRDAO write execution failed. Cannot send cue sheet". I have tried to edit the cue sheet so the bin file was in the same directory, but I can't seem to get past this. Any help or direction. Thanks.
Look at the bottom of VCDEasy. Does it say "ASPI Layer: Not Valid"?
There is no problem with your CUE/BIN file. Rather, CDRDAO can't burn the CUE/BIN image using your drive at present.
If you get the ASPI Layer not valid message, then I suggest that you download and install ForceASPI (and then reboot once): http://www.vcdhelp.com/tools
If that doesn't solve your problems, then you may need to use another program to burn your CUE/BIN images: e.g., CDRWin, BlindWrite or the newer versions of Nero.
Regards.Michael Tam
w: Morsels of Evidence -
It says it is valid, and I get the same problem with Nero. I will check to see if I have the latest version. Thanks for the feedback.
Any Video Thumbnail Sheet Makers for Macs?
By M-O in forum MacReplies: 46Last Post: 2nd Nov 2014, 10:12 -
Best Batch Processing - Video Contact Sheet Creator software?
By binar in forum Video ConversionReplies: 6Last Post: 28th May 2014, 12:09 -
How to share a Excel spread sheet online with different users
By neworldman in forum ComputerReplies: 1Last Post: 8th Oct 2010, 01:28 -
JPEG to AVI (or MPEG2) via timing cue-sheet?
By NetRodent in forum Video ConversionReplies: 0Last Post: 31st Aug 2008, 10:49 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 13:29
