  1. Fix one problem you discover another...
    Source is HuffyUV encoded AVI file, with uncompressed 44.1 Khz audio. This file plays fine in media player. A virtualdub Divx conversion of this file plays fine in Media player.
    When loaded in tmpgEnc, it looks ok, and video is OK, but the sound stops at exactly 1:43 into every file (Tried 4 of them... all in the same format as above). This can also be seen in the advanced settings under audio. I move the slider over past 1:43, and all there is, is a flat line.
    I'm not aware of a source range on audio... just video.
    Help!
    Apr 2002
    The State of Frustration
    If you get audio errors, out of sync problems or bad audio or no audio at all
    Try to convert the audio to wav before converting.
    -- The Newbie Guides
    Here is your guide.
    Hello.
