  1. Ok I was converting a Divx file threw TMPGEnc to burn to a DVD, however when I was finished and it was compiled I played it and it was only 8 mins long in Winamp which it started in automaticallly but before in Divx it was about 50 mins long, does anyone know how to fix it? Thanks.. I was told by someone to run a junk file search in virtual dub but how will that make it longer? and further more do i do it on the original file or on the one i compiled, and how do i run that search? If anyone knows an easyer way please tell me. THanks
    Apr 2002
    The State of Frustration
    Why did you not reply to my post when you posted this problem earlier? Moderator hate multiple posts. It does not get you help any quicker.
    Hello.
  3. Ooops my B, i didn't know. But do you have the answere? I'm not quite clear on your advice, please help, thanks
    Apr 2002
    In Virtual Dub, load your DivX video. Select Video-->Scan video stream for errors. If it reports any questionable frames, edit them out.
    Hello.
  5. Crap i figured it out... the file i downloaded from kazaa when played through divx it says it is 50 mins long but only plays to 8 and it is not the end, it just stops. and is 131 MB (137,425,210 bytes) big so what can i do??????
