    Jul 2001
    Spain
    Hello,
    When I create a CVD with Tmpgenc, I always put the MAX number of frames per gop at 15, to make it DVD standard too.
    But... how can I make this with Cinema Craft Encoder?
    Any help will be apreciated,
    Martí
  2. Member DJRumpy's Avatar
    Dallas, Texas
    CCE shouldn't make your MPEG non compliant, assuming you have a version specific to your region (PAL I'm assuming, since you said your GOP size is 15). In older versions, you cannot modify the GOP structure/size (there are hacks/patches that you can find that will allow you to, but they can cause other problems).
    Impossible to see the future is. The Dark Side clouds everything...
