I have this little problem with DVD2SVCD (newest version) it seems when it does the shit with DVD2AVI it doesnt seem to do anything but just sit there whats the deal with that? i have all the programs and everything and it just sits there and i let it sit there for hrs and it doesnt do anything and its pissing me off![]()
Has anyone else had this problem?
Thanks.
Have you tried to do that part manually, i.e. take the (assumed) DVD and rip it with another tool like dvdx or CladDVD or something and then frameserve it yourself? If you have done that already and it too doesnt work, sounds like it might be something with the ripped vob files.
I am also assuming that you have used previous version of DVD2SVCD and it has worked flawlessly? If you have never used DVD2SVCD before, when it gets to the point of frameserving, AVIsynth is minimized and you would need to right click and maximize it. What I am trying to figure out with that part is it you are thinking that it isn't doing anything, but in reality it is (the frameserving part normally takes 5-20 minutes) actually working. If that's not the case, let me know if the avisynth has data in the appropriate fields when it is pulled up.
MultiAVCHD problems; chapter selection crashes program; changing title
By Yanta in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2011, 16:48 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
Problems converting with Letterbox...what program should I use?
By jubjubkiwi in forum Video ConversionReplies: 1Last Post: 2nd Jan 2008, 08:47
