I installed NimoPack8 and my videos played upside down (as described in detail in the NEWBIE FORUM--Posted 10/20)..
Anyway when I uninstalled NIMO, I lost alot of codecs, NIMO uninstalled what seemed like everything..
I re-downloaded Divx 5.02.
My Elecard Mpeg2 player also seems to be working okay, but not opening all my MPEG2 Encoded Files.
My question is what are the ESSENTIAL CODECs needed to Encode/Simple Edit/Play (S)VCD's.
I don't rip dvd's (Dont own a dvd-rom).
I convert downloaded movies from all types of media types and dowload already encoded movies.
I also preview the (s)vcd's before burning on WMP or Elecard.
I dont remember what codecs I had previously installed, Many Done a long time ago..
Also is there a codec that allows me to open an already encoded (s)VCD in TMPGENC??
I should also note, because it wasnt that clear after I read my post, that the movies I download (whatever format), I BURN using Nero, to (s)vcd, to play on my stadalone Unit..
So any codecs that may be essential to the burning portion I would also like to know..
And If anyone know why the NIMOPAC caused my Mpegs to play Upside Down in both my media players, I'd love to know.
I did 2 installs, One with the bicubic resizer, then when they were upside down, I uninstalled, and did 2nd without the Resizer, bith times I did the full install (Versus the Basic), besides unclicking the resizer, and not installing the codecs they said had a compatibilaty problem at the start of the install.
I would love just install the full Nimo Pack and have everything..
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Codec info
By stigslim in forum Software PlayingReplies: 3Last Post: 11th Feb 2009, 03:33 -
xbox360 won't play this avi,, codec info inside
By sance in forum Media Center PC / MediaCentersReplies: 11Last Post: 24th Dec 2008, 12:11 -
Help/info on IV50 "Indeo Video 5" codec....
By petruccibanez in forum MacReplies: 3Last Post: 4th Apr 2008, 00:22
