I always use VCDeasy to create my binfiles. My file is 780mb and my binfile
about 900mb!?.I never had this problem before. Am i doing something
different maby?
Your MPEG probably "bloated" in size due to autopadding.
This implies that you MPEG wasn't muxed correctly.
If your MPEG is VCD compliant, then remux your MPEG with TMPGEnc --> MPEG Tools --> simple multiplex and change the setting to "MPEG-1 Video-CD".
If you are making an XVCD, then change the setting to "MPEG-1 Video-CD (non-standard)".
If you are making a X/SVCD, then change the setting to SVCD or (recommended), remux. your MPEG-2 file with bbMPEG on the SVCD setting.
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
