I have Pioneer DVD -RW DVR 104 Writer. After creating DVD I can
read DVD using this drive. Also I have DVD reading ROM 16 times
speeding. Here is the problem. When I put DVD Copy into this drive,
DVD reading ROM couldn't recognize DVD.It means It can read. I was
trying Power DVD to open movie on my computer. I can use DVD Copy to watch DVD on DVD Players. If somebody can help me, Let me know.
Dragan Jovanovic
I'm having the same problem, I have the same burner. It only recognizes the real dvd's not the dvd-r's as far as movies i think. It may just be the burner though??
Thank You for answer.Maybe You know any other burner who
recognize dvd rom.
Thanks againDragan Jovanovic -
Many DVD-ROM drives out there at the moment do not read DVD-r media. The Drive that wrote the disc should read it ok.
Also check the media. I had a problem with super cheap generic disks not playing in DVD-Roms. I upgraded to Apple disks and they play fine.
Maybe You are right.I bought super cheap disk 0.9 $ USA.Can You give m suggestion for any otrher DVD Media.
ThanksDragan Jovanovic -
Like I said I upgraded to Apple DVD-R disks and they work great. Any name brand like Apple, Pioneer, TDK, Sony, Memorex should give you much better results
cd drive not readind disc created many years ago?
By mikehende in forum AudioReplies: 18Last Post: 23rd Nov 2011, 16:47 -
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 10:33 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 17:19 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 11:04 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
