hi all i have a 700mb avi file.... i want to covert in to mpg to burn to vcd using nero... but after like 10 hours of conversion... the file turn out to be a woooping 2G..... how am i gonna burn it to a standard cdr now??? thanx
i tried buring the avi w/ nero but after hours of encoding.... nero just shut down w/ nothing written on the disk... really need help thanx
Try using TMPGEnc templates to convert your video before Nero sees them.
Hello. -
well.... i've convert the avi file to mpg.. but the file is 2g in size.. i decided to give it a try anyways.. but nero said something w/ the bitrate.... sorry... i'm really new to this... can anybody tell me if there's a software that i can use to convert avi to mpg... without a big jump in side.. afterall i still need it to fit in a cdr thanx... my avi movie files are ranging from 650mb to 720mb
thanx -
Did you convert using TMPGEnc? And have you ever tried the guide that puts one movie on one CD-R?
Hello.
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 15:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 22:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 06:59 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35
