  1. Ok I am trying to convert a divix file off a data DVD and I have Divix 5.0.2 bundle pro, however, when I run TMPGEnc and find my file off the DVD it says unsupported, so i went to install divix 3 like the instructions says to , but when I go to install DiviX_311 it says:
    The software you are installing for this hardware:
    Sound, video and game controllers
    has not passed Windows Logo testing to verify its compatibility with Windows XP.
    CONTINUING YOUR INSTALLATION OF THIS SOFTWARE MAY IMPAIR OR DESTABILIZE THE CORRECT OPERATION OF YOUR SYSTEM EITHER IMMEDIATLY OR IN THE FUTURE. MICROSOFT STRONGLY RECOMMENDS THAT YOU STOP THIS INSTALLATIN NOW AND CONTACT THE HARDWARE VENDOR FOR SOFTWARE THAT HAS PASSED THE WINDOWS LOGO TESTING.
    and then it gives me to choices to continue anyway or to stop if anyone can help me it will be appreciated. THANKS
  2. What version of Windows are you using? If it's XP, that message is just its way of letting you know the software you're installing doesn't have Microsoft's stamp of approval. If you got it from a reliable source, there should be no problem with letting the install continue.
