PIONEER DV-444!!! How to disable macrovision on this unit?
Sorry but I dont understand. Your dvd player just plays the dvds. It is the recorder that has the macrovision copy protection. ?????
in response to Troyvcd1,
DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors.
i'm not sure but i think u might need some hardware upgrade to disable the macrovision on this model ( i could be wrong though!), unlike early apex dvd players where u could disable macrovision from an on screen menu.
i think the only quick hack that can be done on your model is a region change
Originally Posted by troyvcd1check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation
HELP! looking for a stand alone NON-TV Capture unit
By lostinlodos in forum Capturing and VCRReplies: 9Last Post: 20th Jul 2011, 20:10 -
How to disable macrovision in Go Video DV1140
By wbsearch in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 23:10 -
What is this time unit?
By Charmer in forum Software PlayingReplies: 13Last Post: 8th Aug 2009, 08:52 -
Disable Forward
By modtec in forum Software PlayingReplies: 2Last Post: 27th Jan 2009, 12:46 -
Macrovision decoder or remover in unit
By mysabel in forum Capturing and VCRReplies: 3Last Post: 19th Jun 2007, 16:12
