I want to burn MPEG files using Roxio Easy CD Creator 5. Platnuim but I get this messege when I drag the file into the burning stage, "To make this file video CD compliant, you will need to use an MPEG encoder that supports Video CD encoding." I don't know what program there is to use or how to change it to into the right file source. If anyone know how to please give me an e-mail or reply back.
Naslund
ONE topic one ONE forum is enough!
I would try VCDEasy or Nero instead of Easy CD 5...a lot of users have problems with easy cd vcd. -
And to answer your question, there are many encoders capable of VCD compliant encoding.
I would recommend TMPGEnc as a good choice (freeware)
Among the popular choices (non freeware):
Xing Mpeg Encoder
Panasonic Mpeg encoder
EO Video
Ligos Encoder
Quite like the results with Panasonic Encoder.
Cheers -
OK.I have Roxio 5.X Platinium,but never used it.So,if your file is resolution 320*240 or 352*288(PAL),but not a vcd compliant file,so burn it as a non-compliant vcd file,so called xvcd.Most stand-alone players will play your cd's.Try it,but use Nero5.XXXX.
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 10:27 -
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
I'm dreaming of: A media player that looks like iTunes and supports MPEG-2
By HitTheRoad in forum MacReplies: 1Last Post: 9th Aug 2011, 09:00 -
Which AVC/H264 Encoder Supports Interlced PiCAFF and MBAFF?
By Bonie81 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2010, 11:28
