Hi! I have a problem with FfmpegX and I don't find a way to fix it, I've seached the forum but I didn't find any answers...
I'm trying to make a standart VCD from an AVI film that's in 16:9 format (the size of the avi file is 720x432), I select the VCD quick preset on FfmpegX and the process goes fine but the VCD that I obtain have a distorted image, I would like to have the image in letterbox format, with the 2 black bars on top and bottom, but I obtain a distorted image after encodding the film... I've tried the UNCONSTRAIN, 4:3 and 19:9 AUTOSIZE options but I get the same result.
Can you help me?
Thank you very much!
Andreu
Put the avi in a .mov wrapper, ie open it up in QuickTime, Select All, New Player, Paste, Save, with dependancies.
This will give you a small .mov file the references the avi.
ffmpegX will then use movtowav and movtoy4m and feed the video into yuvscaler; this is where the automagic black bars computation comes from.
So in summary...if you want the nifty black bars magic, you need to use QuickTime movies.
-K[/quote]
I am not positive about this but there is a "VOB Letterbox" check box in the options of ffMpeg. I think that if you select that option you will get the black bars you are looking for.
-Squeed
VCD & SVCD Support For MAC
http://www.squeeds.com
Hi KaiCherry thanks for your info but it doesn't work... i create the small .mov file that references the AVI as you said but then , I get this message in the terminal window:
Last login: Tue Oct 22 16:33:27 on ttyp1
pbpaste | sh
Welcome to Darwin!
[PA1-1A-u-0285:~] andreu% pbpaste | sh
header not found !!!
-2 is not a valid mpeg file
(Super) VideoCD xml description created successfully as `/Users/andreu/Desktop/testfilm.1.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
**ERROR: could not stat() file `/Users/andreu/Desktop/testfilm-1.mpg': No such file or directory
(Super) VideoCD xml description created successfully as `/Users/andreu/Desktop/testfilm.2.xml'
++ WARN:
++ WARN:
**ERROR: could not stat() file `/Users/andreu/Desktop/testfilm-2.mpg': No such file or directory
Encoding complete!
I use the VOB or DVIX to VCD (PAL) Quick Preset... Do you know if I'm doing something wrong? I've tried the MOV to SVCD Preset too but it doesn't work and I want a standart VCD... can you tell me if is it possible to encode it setting the pressets manually?
Thanks again!
From 4:3 letterbox to 16:9
By Crueltylizer in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2010, 10:40 -
Letterbox 4:3 to Anamorphic 16:9
By sjdean in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 17:09 -
Is there any way to force ffmpegX to letterbox?
By AVR2 in forum ffmpegX general discussionReplies: 6Last Post: 27th Jan 2009, 17:17 -
letterbox to 16:9
By marksk918 in forum Authoring (DVD)Replies: 9Last Post: 30th Aug 2008, 02:33 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 03:57
