I am looking at ways to convert my DV files to DVD quicker using TMPGEnc. I am currently running off a COMPAQ ML350 server, PIII 600Mhz, 256 Mb PC133 Ram, 3 SCSI in a software Raid configuration. Running WinXP pro on the box.
Everything is working well as far as capturing video from the Digital camcorder to disk and the conversion to DVD format is working without a problem as well. I just would like to speed up the process. What is the best piece of equipment I should upgrade to get shorter conversion times?
Thanks in advance for any advice,
Gatorguy
faster cpu ... going to a p4 make a heap of speed increase ..
win2k is a little faster than win xp but marginal diff ...
get the dual option for your machine will help a lot also ..
but over all faster cpu will make most diff.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
