I just read that my DVD player can read XSVCD's, and pretty much any other type of media.
What program can make XSVCD's? Can I use nero. Also can TMPGEnc encode at the bitrate for XSVCD's?
Yes. If not compliant SVCD bitrate is used, Nero offers to make XSVCD. TMPGEnc can encode at any bitrate.
What do you mean by if not compliant SVCD bitrate is used. Where is that setting in NERO?
It is hard-coded into Nero (2748kbps combined). If Nero notices max bitrate higher than that, it offers either to re-encode or make XSVCD. Just encode Your vid and drop into Nero
Sweet thanks. I've been trying different encoding setups... right now i'm doing my episodes in SVCD, 480x480 (which i heard it good) 29.97 fps, 1950kbps (Should i make this higher?) with 2 pass VBR.
Sound good or should I adjust that? Looking for best quality -
Originally Posted by TheDeputy
since you didn't mention one way or the other...I might guess that your audio is at 48khz instead of the SVCD 44.1khz which is what's bugging Nero.
just a guesswhat are you askin' me for...
I'm an idiot! -
Nope actualy its at 44.1.
I know the specs I had there were not XSVCD, i figure I might as well stick with SVCD, I heard that it's better off anyway.
So with the specs I gave that should provide me with the best quality of SCVD then?
Making clips
By kamyogi in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2009, 05:03 -
Making subs like these
By NangelK in forum SubtitleReplies: 11Last Post: 31st Jan 2009, 12:26 -
making one mov from several
By extremelyslow in forum MacReplies: 3Last Post: 14th Oct 2008, 15:01 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making Widgets
By redstripes in forum Off topicReplies: 2Last Post: 16th Jan 2008, 10:43
