  1. proctor
    Guest
    Hi,
    I ripped a DVD and I made the two VCD file.
    All throughout the movie, the audio comes a fraction of a second before the video. From the beginning of the movie to the end (I think).
    What can I do to sync them?
  2. when you had the AVI, did you check for bad frames?
    What's the file typ of the video file you have... (mpeg 1 or 2?) cuz when it's 2, you can have codec problems (like i do ) and in fact it's correct, there is no problem
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    In short:
    • Demux video and audio with TMPGEnc
      Load audio into audio editor (Cool Edit, Goldwave, Soundforge...)
      Insert "fraction of a second" silence at start of audio
      Save as wav
      Reencode wav to mp2 with tooLame or wav2mp
      Multiplex video (from step 1) with new mp2 using TMPGEnc
      Done.
    /Mats
  4. proctor
    Guest
    I don't really know how to do all that :\
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, then I might suggest a look at the Howtos under the heading "How to repair downloaded video clips or fix audio sync problems", to the left of this message !
    It describes things in more words, but boils down to what I wrote before...
    /Mats
