I have played around with the settings on TMPEnc and have created a VCD with a resolution of 720x480 by using the resolution setting of 1:1 VGA, encoded from an AVI original.
It plays perfectly well in my DVD player, so I just wanted to know, is this strictly a VCD, but should all VCDs be at 352x288?
The amount of space on the CD is not of SVCD standard, as the bit rate used is VCD 1150 kbits.
Cole
Originally Posted by Cole
You have created something called an XVCD or Extended Video CD. Some DVD standalone players will play them and fortunately, yours do
So no, you dont have to stick to 352x240/288, but just remember an XVCD is outside DVD specs and will not work for everyone.
I prefer the higher resolution VCD (352x480 or 704x480) with average bitrate around 2000 myself. -
I think that you can gather that I am a bit of a newbie at this, but thank you for your info. I am still in the experimental stage and still trying to find the settings that I like the most.
Thanks again.Cole
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 13:23 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 08:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57
