I start with a .avi File and want to make it a Mpeg using TMPGEnc. Everything goes smooth while it is doing the proccess. I get no errors. When it is all done and I try to view the new file, There is only audio. The file is still like 400Megs. But no video. I followd the instruction to a tee. Mabey thats the problem? If this helps, when I go to the cutting pallette that is included with TMPG I dont get any picture there either. If anyone can help it would be very much apreciated.
Chris
there IS video in your file, you're just missing the codec to see it...
get the Nimo Codec pack you'll find under the TOOLS section of this siteWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 16:53
