I have been trying for days to backup my DVD's to DVD+R+RW i have followed all the user guides and had only one success I managed to record the Simpsons backstage pass DVD with no problems but anything else I try using the sme software and settings does not work I must be missing something.
HELP
I use smartripper
ifoedit
Nero![]()
Thanks I am away from the PC that I use so when I get home I will give more info it just puzzels me that I have burned a DVD and using the same process everything else fails but I will give a better decription when I get to my own PC
Had a look at that tutorial one problem is I dont have DVD Maestro where can I get it from Thanks
Oh I always get the message from Nero 'unexpected file format' -
kazaa or grokster.
Also about your former problem try burnning your DVDs with prassi primo DVD instead of Nero. It works wonders for me!(Data DVD or DVD from Image file both play just fine)
Good Luck
Thanks I have had a success burning single layer disk True Romance so i think my problems lie with my decodeing of dual layerdisks I will keep trying and hopefully get the right formula
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
