i have a short movie that i am playing with to test things out... i got it from kazaa - it has saved itself as quick time movie player format - well thats wot it says under file type, but it mite be mp3.
Anyway, i burned it to disk using Nero and used the svcd format (yes i have the plug in that converts files).
went to play it on DVD on computer using PowerDVD software that came with PC and it wuoldnt accept it.
So i tried again, but this time saved it as DATA and it then played on my DVD software.
Why wouldnt it accept it as SVCD?
Any suggestions - is it my DVD software or are computer DVDs different than normal ones.. as u can tell i am a complete newby to DVDs/Burning/ etc.. but pretty up to date on other things...just all new to me...and takes ages to read through everthing to understand!![]()
Thanks for reading!
after looking at my DVD software PowerDVD - i have been to the site, and it seems that my software is quite old as it doesnt accept SVCD format, but that shouldnt be a problem now as i can upgrade to their current version that does accept SVCD.
so - hopefully problem sorted!!!
Multiple computers?
By DGenerateKane in forum ComputerReplies: 3Last Post: 25th Apr 2011, 10:28 -
Audio in my video doesn't work on all computers
By MattMedia in forum AudioReplies: 4Last Post: 26th Jan 2011, 11:40 -
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 18:03 -
Is this true? DVD can't be played on older computers?
By jjachin in forum Authoring (DVD)Replies: 23Last Post: 12th Nov 2009, 11:49 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 22:51
