Is there a guide for coverting a downloaded AVI to a quality VCD. I download a 29 FPS AVI file and used VIrtual dub to capture, TMPGNE to encode and VCD easy to Burn but the quality was poor. I am not highly knowledgeable and need a basic guide to walk me through and provide some background on the topic. Anyone's help would be appreciated
You've tried this guide?
http://www.vcdhelp.com/tmpgenc.htmPanasonic DMR-ES45VS, keep those discs a burnin' -
This is something I did a couple of years ago. If you read through I take .avi and convert to vcd mpeg1. The software has changed over the years and I haven't done the conversion in a while, but it should help.
http://www.geocities.com/mr_bubba_zanetti/vcd1.html -
virtualdub to capture? do you mean virtualdub to convert the audio to wav or?
You could try SVCD/CVD if your source is good enough, garbage in - garbage out.
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
Asafs TV Episodes to VCD-DVD guide
By angelheart in forum User guidesReplies: 4Last Post: 19th May 2008, 21:47 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25 -
Philips DVDR7310H: search (Guide Plus) doesn't work anymore
By Monco in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Aug 2007, 13:05 -
Need help geeting TV Guide to work with my Toshiba RD-XS34SU
By ITIL2 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 07:27
