Hey everyone-
I seem to be having a problem with capturing a DVD with Dazzle Digital Video Creator. It seems to me as though I record everything, and it is fine, but when i go to play it back I get a horrible static noise that goes along with the voices. I have my audio settings to real-time recording, and I don't have my audio levels up too high. If anyone could help me, it would be great. Oh yea, I'm capturing off of a DVD player. Thanks for the help. If you need me to be more specific, let me know. I'll be watching the posts. Thanks for all the help in advance. Later
- MQ
I think your software with the DVC comes with Moviestar. Check the audio input gain control which is normally set to "70" and lower it to "50". If this too doesn't work try asking this question at
http://stop.at/dazzle2
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-04 19:07:48 ]</font>
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 15:14 -
Problem with Dazzle
By brad1983 in forum Capturing and VCRReplies: 1Last Post: 17th Jun 2010, 13:20 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 14:53 -
Dazzle DVC 170 PAL Problem - 'mirrored' screen
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2007, 07:58 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34
