How can I burn a VCD with Nero that will really play? I made a VCD with the directions here: http://www.vcdhelp.com/nero.htm. It will play on the computer by accessing the .dat file but the DVD player just spins at a high speed then ejects the CD! Is there some way to make one that works? TIA
Not all dvd players will play burned VCD's and some dvd players dont play cdr's or cdrw's.
Check the compatability list to see what your player can handle
http://www.vcdhelp.com/dvdplayers -
I know that! It's a Sharp DV-600, the chart says it plays VCD's.
However Windows Media player can't play the VCD if I just put it in and click on Play. I have to find and select the .dat file before it will play.
How does a DVD player have any chance of playing it? There's no way to select the .dat file manually so I don't see how it could ever work. -
If your dvd player supports VCD then you dont need to locate like on your computer. it should just start playing it. Also if you would read my full post and follow what i said you find out that your sharp dv-600 does not support CDR's according to the chart. It will use cdrw's or professional VCD. If you want to have your computer auto play it you can create an autorun.inf file and burn that as part of your VCD, But thats a whole other topic
CD-RW? That sucks, my disks are only 4X so it will take forever to record.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Cant' get these to play or burn right?
By sj022698 in forum Authoring (DVD)Replies: 1Last Post: 5th Feb 2008, 16:52 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10
