Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hello here.
    I'm new on ffmpeg for MacOS X and I'm trying to convert a normal Quicktime .mov to a SVCD compliant MPEG file. Well, all seems to works fine but when I try to see the resultant muxed file with VLC the video is jerking... this happen even on my Philips DVD622 standalone player.
    I use the SVCD (PAL) quick preset of the ffmpegX program.
    Any idea?
    Thank you for any advice.
    Sincerely
    Fab.
    Nov 2001
    squeed
    It sounds like your bitrate is too high. Try lowering it to less than 1500.
    -Squeed
    VCD & SVCD Support For MAC
    http://www.squeeds.com
  3. Thank you Squeed for your kind reply.
    Now I'm trying, but I'm wondering....does the "classical" SVCD bitrate is 2500?
    Thank you for your kind thought.
    Sincerely
    Fab.
  4. Hey Squeed, I've just tried but the problem persists... even at 1300 as bitrate... any other help?
    Thank you!
    Fab.
