I am using virtualdub with my win tv go pci card and cant get a high resolution picture. do i need new drivers . If i go higher than 352*288 i get unsuported format.
What do i do ?
It's the same for me, I have a Pinnacle PCTV and the max resolution in capture is 352x288. Hope someone can help us.
Check this site to see if these drivers support your card:
http://btwincap.sourceforge.net/Panasonic DMR-ES45VS, keep those discs a burnin' -
I have tried new driver from sourceforge but it wont work.
I get This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device.
What amm i doing wrong
HEEELLLPP
Grantwalsh,
I presume (given your reference to VDub) that you want to capture at higher resolution than 352*288. Well, according to Hauppauge UK support, the card will not allow higher res captures (even though the tabs in VidCap or WinTV32 say otherwise). I only found this out after buying one!
Rob -
The key is that you need a VFW driver and not a WDM driver. Happ. only offers a WDM driver.
I just went through this again over the weekend with a new install of XP. Previously, I was using a third party VFW wrapper, which I think was called Coxial or Concentric or something... could have come from sourceforge. Worked well.
When I reinstalled, I couldn't find that wrapper again... I should have written down what it was using! But what did work for me this time (and not previously) is to install the Win2000 or NT VFW driver which is available on Happ.s site. I get some error windows when starting up capture mode in virtualdub, but then it works.
So, try the NT VFW driver. The file name is w2kdrv311.exe. Make sure you delete your WDM drivers first. This NT driver also does not have a TV tuner in the options in VirtualDib, so I have to use the WinTV2000 app to tune to the right channel to capture first, then load up virtualdub.
Good luck!
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58 -
Flash FLV Internet Video Larger than 320 x 240
By foochuck in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2007, 12:49 -
I can only capture at 320*240!!
By MisterBubbles in forum Capturing and VCRReplies: 1Last Post: 13th Jun 2007, 22:36
