Results 1 to 19 of 19
  1. I am havin prob with this prog. Every time i cinvert a avi to svcd the video is blockey. It is as if the block are in the wrong place on the screen. They are not small pixel block but big squair blocks. There must be some one out thair that has had this prob please help. If could work out how to put screen shot on this post i would show you.
    Jul 2002
    Erie, PA United States
    Mike229,
    You need to post some details on your encoding process before anyone can help. For example whether or not you used 1 pass or 2 pass encoding, what your minimum and maximum bitrates were ect. Just off the top of my head anytime you see excessive amounts of block noise it's due to too low a bitrate. Need more info.
    Warning! I'm baaaaaaaaack
  3. Hello my mate i hope you can help . Just used the setting that you have when it sarts up! What setting would you suggest? It only seem to happen when it getts to thge end of the cd that i am watchin, and every timee i convert it happends at diffrent places!!! Can you help!
    Upstate NY
    Ok dO i have this straight...
    When watching a (VCD/SVCD/OTHER ) on my ( COMPUTER/DVD PLAYER ) off of a ( 74 minute/ 80 minute/90 minute/99 minute ) CD-R you often get blocks that look like ( reduced resolution / rainbow colors / misplaced video all over the screen ) for a few seconds.
    If you fill in the blanks I think we can help. It sounds like your DVD player may not like the type or speed of your cd-r media.
  5. Have tryed diffrent media. And is the same on the computer and DVD playey. The blocky bits are in the same place on the cd when play back on puter or DVD. And is not a few second's it can be minites at the end of the cd!
  6. I think i am lookin to much into this. Thair must be a simple explanation, a box i have to tick. Cum to think of it it has got worse since i ugraded to TMPGEnc Plus!!! How do you put a image on hear to show you the picture quality i am getting!
  7. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    The fact that it got worst with the latest version of tmpgenc is more likely because you had a default template setting which is no longer available. Most of us don't go with loaded defaults but either use templates (available on the left panel) or manually tweak the settings (bitrate, noise filters, resize et....).
    If it only happens with 1 movie then it could be that particular video itself that has a problem but if it happens with all your movies then it points to your settings.
    Why not try an svcd template look on the left under other...tools...tmpgenc templates and see if one suits your needs.
    There's not much to do but then I can't do much anyway.
  8. Could this be that the fim is 29fps and i am trying to save it as 25fps?
    Jul 2002
    Mike229,
    Aside from the fact your trying to convert from NTSC to PAL which in itself has too many issues to list here, I still think your max/min/average bitrate settings are way to low. One thing you never mentioned was how does the original avi look on playback? If your source material has a lot of noise in it to begin with your final result after encoding isn't going to be any better. Also what burning software are you using? Going back to my original post that's why I suggested posting some more details. All were doing here is a guessing game. The more details you post on your encoding/burning process the more specific the answer can be.
  10. SORRY here we go.
    Avi file is perfect no noise!
    Am using nero 5.5.9.9 to burn disk. Tryed all diffrent burn speeds.
    Am using 2 pass vbr min=300 max=2520 av=1971. Not changed this. These are the values given by TMPGEnc.
    Soften block noise on Both at 35.
    Aubio has been extacted by vitudud.
    Not altered any noise reduction settings!
    Any more info i can give!
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You say you use Nero to burn - are you sure Nero is not reencoding the MPEG? That would reduce the quality for sure!
    /Mats
  12. All i do is click on the svcd and drag on drop the file in! It never says anything about re encoding he file!
  13. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Not sure it will, either - Nero has a mind of it's own. Make a try with VCDEasy instead!
    /Mats
  14. Still having probs with this!
  15. Member DJRumpy's Avatar
    Dallas, Texas
    Nero will not re-encode without warning you first. Mike, where did this AVI file come from? Is it a from a CAM?
    Impossible to see the future is. The Dark Side clouds everything...
  16. All are DVD rips of the net. Watched them in dvix and windows media and the play perfect!
  17. Member DJRumpy's Avatar
    Dallas, Texas
    Do these blocks show up in high actions scenes? Are they just kind of a distortion (smokey) appearance, or are they actually different colors, like bright green, or pink?
  18. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Judging from the amount of problems people seem to have, clearly coming from Nero reencoding what's already a perfectly legitimate XVCD mpeg, Nero is obviously not too clear about its intentions...
    /Mats
  19. Sorted it! Nero is the problem! VCD easy it is perfect. Thanks for all your help!
