How do I get to fiddle with keyframes with my captured video?
See, i´d like to experiment with different settings.
Can anybody show me the STEPS?
do you want to insert one ? or change how many frames between keyframes ?
and what software are you using to do this (or planing to use)?
it will not change the quality of anything if that is your object .. -
I´m intending to use virtual dub but don´t even know if I can do that with it. Any suggestions?
Yes, I wanna change how many frames between keyframes.
I want to experiment with it to see how that affects the progress bar on my media player.
Thanks man, -
media player dosnt like files encoded with VBR .. i can tell you that ... with VBR files you have a hard time using the slider ..
I´m capturing with Win TV PVR but it doesn´t give me any options to play around with keyframes.
Total keyframes?
By anonymous_whatever in forum Newbie / General discussionsReplies: 41Last Post: 12th Feb 2012, 11:33 -
Listing keyframes
By Misterer in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2010, 11:36 -
Are variable keyframes possible?
By x2x3x2 in forum Video ConversionReplies: 15Last Post: 7th Aug 2010, 08:40 -
Increase the density of keyframes
By Stasik0 in forum EditingReplies: 11Last Post: 6th Jul 2010, 08:15 -
Are I-Frames the same as Keyframes?
By leopard in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2009, 08:23
