OK...... when i try to open a movie (just wit Xvid Codec) i get a message that says error not supported and doesnt open. So i went to Environmental Settings and changed the Media setting from -1 to +1. It is just that the mpeg conversion is a little moer "choppier" then the original *avi. movie. Is that normal? Like what does that setting actually do? Is there a way in which i can open the file and convert it as "clean" as the original movie??![]()
You can open the Xvid avi right, thats all changing the vfapi priorities did, allowed that to happen.
If you have choppy/jerky video its a different problem. My 1st guess would be you encoded in Tmpgenc to a different frame rate than the original avi. Check this and re-encode to the same frame rate or look in the guides on how to do standards conversion.
Hope this helps. -
No..the original *avi. movie is perfect at 23.967 fps...... and i converted it with ntsc film template thatr is why i dont understand what changing the Vfia plugin settings?
Error Message when selecting a movie in VTS
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Sep 2011, 15:08 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 13:53 -
Error message popup when opening folders with vids
By majax79 in forum ComputerReplies: 32Last Post: 26th Sep 2007, 02:31 -
Windows Movie Maker Error Message
By Jedi5 in forum Newbie / General discussionsReplies: 8Last Post: 25th Sep 2007, 23:17
